Renovo Soft top reviver
Have you tried cleaning it with correct stuff and re sealing <water proofing>
did this on mine comes up really dark again.
Also says on the tin "Not for vinyl soft tops", so no good for an S2000 with original roof.
I gave mine the works today, with aerospace 303 cleaner,, and as I've run out of Raggtopp and 303 protector used the Autoglim vinyl protector it came up nice and black.
I use renovo but not that one, the one in the green or maybe brown tub? Does the job.
I've tried the Auto glym cleaner and proofer on a small section.I would'nt say its come up much different.You can see the outline of the frame under the material which is what I am trying to hide.
I think the vinyl has probably stretched (it's the same on mine) and what ever you use it will still show to a degree. I was using Autoglym for last two years but will be using 303 this time and I still expect to see the outline of the frame.
