Removing Rocker Box
Removing Rocker Box
Hi all,
I have done a little project with a donar rocker box and I now want to fit this to my car, is there any guides on how to remove this?
Also is there anything I should consider changing while this is off?
thanks
thanks
You may wish to replace the gasket at the same time if yours leaks, otherwise leave it be.
It's a really simple job, just remove what you see, taking care of the electrical connectors.
When re-fiiting be careful when tightening the bolts back up!
They have rubber washers which can remove some of the 'feel'. It's a pain in the arse if you snap a bolt, as they arn't the strongest.
I recommend getting the service manual. Someone has a link to one you can download in their signature.
All the valve cover spark plug and spark cover bolts need to be tightened to 12nm, the 5 that secure the cover itself need to be done in the following order:
Middle right
Top left
Bottom left
Top right
Bottom right
I'd apply thread-lock to the ones that secure the spark plug cover, these are prone to rattling loose and dissapearing.
Middle right
Top left
Bottom left
Top right
Bottom right
Originally Posted by RUSS H,Aug 10 2009, 07:01 PM
Here is a lovely photo of my old mint S2K
The 'gasket' is a rubber seal so dont worry about that,
im sure the torque was around 10nm ??
Russ.
