Removing front plate holder.
I did a search but no answers.
I can see two bolts on the plate holder which I have removed, but it still seems to be attached onto the bumper.
Are there more bolts attached to it? I can't see any though. I don't want to rip it off and damage the bumper.
There are 4 bolts, two are small, 2 are larger. The larger ones leave noticable holes. Blanking plates can be bought.
Its easier to remove with the bumper off the car.
Mike
Mike
Squirt a drop of mastic around the bolts/nuts and leave them there , my stayed put for 12 years
The bumper comes of fairly easily but the lower bolts can be badly rusted along the bottom front edge , these are the one that fit into the funnel nuts.
I have found that you can use virtually any M6 funnel nuts but i could n't get stainless ones. Use M6 Stainless bolts and washers when refitting the bumper , they are relatively cheap form your local fastener supplier who should also be able to supply replacement funnel nuts.
Getting the bumper lined up properly when refitting is a matter of be ing careful and taking a bit of time , you do see lots that are to say the least a tad wonky , rears are the worst.
