removing front lower wishbone?
#43
Originally Posted by LTB,Apr 9 2007, 11:25 AM
Thanks for that, really appreciate it.
I have to speak to my dealer just to confirm exactly what parts are needed before I order, but can't do that until tomorrow as it's a bank holiday.
Rear drop link (or "sway bar link" as the Americans call them) - L1030-150365
Right drop link - L1030-150363
Left drop link ????
#44
Originally Posted by Si2k,Apr 9 2007, 11:28 PM
Expensive bolts too! You would of thought they didnt rust at that price
Question: Which is the best but inexpensive plating solution?
Frost plating kits
#45
Originally Posted by StevenM,Apr 9 2007, 05:41 PM
That was the bolt I had to remove with a hack saw
#47
Left drop link ????
Left drop link ????
#48
Originally Posted by Si2k,Apr 10 2007, 12:33 PM
Is the bolts corroding into the captive nuts an issue?
#49
I would strongly advise anyone with a new(ish) S to center punch the position of the adjustable bolts, remove them, clean them up with wet+dry then carefully grease the bolt and the bushing to exclude further corrosion.
Then take advantage of Chris at Centergravity to have the alignment correctly set.
This alignment alone has transformed my car.
I'm glad I did this to mine before the corrosion was advanced enough to stop their removal.
This is the rear bolt from my car that you could not remove from yours.
#50
I think I said it before long ago when this problem first arose.
When you come to building up use "EP2" grease, general purpose or for that matter Copper slip is poor in comparison.
There's no need for plating.
