Removal of Badges
Old 04-23-2003, 03:37 AM
Crusader Rabbit's Avatar
Side badges will come off in 2 minutes flat.......easy. Glue took me longer to remove (10-15 minutes per badge?) using WD40 but you may want to try the bug/tar remover instead.
Front/rear badges........probably about 10 minutes each once I'd worked out what to do from Rick's instructions. Then same sort of time as above for glue removal.
Net......does not take a long time at all. Once you've sussed what to do, badge removal is easy. Main time taken was on glue removal afterwards.
Old 04-23-2003, 03:45 AM
zero_to60's Avatar
thanks for that....the clean look does appeal and the shinyness of the badges looks a bit cheesy to me.....this is one area where BMW does it better
Old 04-24-2003, 02:31 AM
BigTed's Avatar
Another tip is to use a tape-type dental floss, and not the normal fibre-type dental floss, as the fibre-type floss breaks too easily. Johnson and Johnson used to make a tape-type dental floss under the Reach brand.
Old 04-24-2003, 02:37 AM
moff's Avatar
Anyone got any pics of a Silverstone car with the badges removed?
Old 04-24-2003, 03:28 AM
A_Wooly's Avatar
I think I've gone too far with mine
Wooly
Old 04-24-2003, 06:44 AM
Tifosi Red's Avatar
Probabaly not what you meant though!
I have had to remove the front and rear badges twice now (once to fit the red ones and again to re-fit the original Silverstone ones prior to selling the car) and found these instructions very useful:
Badeg removal intrsuctions from HandA
All the above tips are good too, be sure to mask around the badges before starting though to prevent any scratching of surrounding paint.
Tif
Old 04-24-2003, 09:51 AM
Mans Best's Avatar
hope this helps
Old 04-24-2003, 12:15 PM
ianl's Avatar
Here is my Silverstone car recently (last Saturday) relieved of its 'Honda' side badges.
As others have said - getting the badges off is a doddle. Removal of the glue is a pain - I found a combination of Isopropyl Alcohol, WD40 and Autoglym extra gloss protectant (I dont know what they put in this stuff, but it is brilliant at removing sticky stuff like tar and glue!) along with a little patience worked well. Finished off with a Fairy liquid wash and a damned good P21S waxing and you really wouldnt know the badges where ever there!
Old 04-24-2003, 12:23 PM
moff's Avatar
Cheers , thanks for the pics.
I think I will remove the Honda badges and leave the S2000 badge on, IMO looks a little bare without it.
ps love the number plate
TheLoons12
02-15-2007 08:12 PM
MitsukillinS2K
04-07-2006 06:52 PM
The Raptor
02-23-2004 09:25 AM
toecheese
05-22-2002 02:58 PM
Quick Reply: Removal of Badges
