Recommend me some plugs (from ok to oh ohh)
As title I was getting a miss fire and it was not idling as smooth as normal, I've took a plug out this morning ( I have not changed the plugs since owning the car ) and out came a bosch superplus fr6kpp33x+, I don't normally use bosch plugs so what is the recommended plug ( I think this engine was boosted in a previous owners hands)
BKR7EIX, still Iridium, lasted ages and worked well on my car. Cheaper than the PFR.
Yeah, they do read better than the platinum ones don't they? I was trying to figure out why I chose the PFR7G-11S for the last plug change and I'm sure they (PFR7G-11S) were just cheaper at that time. You'll need to gap those ones but they do make a pre-gapped BKR7EIX-11
1.1mm or 0.044" if you like decimal imperial
and to be fair those Bosch look good on paper although no idea how their temp rating works in comparison to NGK - might be a little hot at 6 in their range
Thanks Ben the car has run fine with these plugs since ive had the car in 2014 ive only don just over 5k since then.
i have noticed little bits with the car it has got Toda cams, adjustable cam gears valve springs, there is a funky little box connected to o2 sensor curcuit by the ecu ive also noticed it has a return on the sump so make me think it was boosted by a previous owner and the stuff taken off before i got my hands on it
