Rear Wheel arch Liners
Having looked at a few S2k i noticed the early ones seem to be prone to rust around the wheel arch liners. Given these are similar in design to the door edge strips you can buy that also cause rust what is the consensus of opinion re theses things.
It had been suggested to me by a bodyshop that I remove the liners clean up the arches, paint anyd scratches and chips and then carefully reapply the liners and seal them on with a small amount of clear silicone all the way around. They said that the biggest problem with the liners is fine gravel/ road salt getting behind these and scratching through the paint with vibration... Obviously this then leads to rust through time.
I quite like the idea of cleaning them up and either getting new liners or re using old ones and sealing the edges with silicone to prevent dirt ingress?
Anyone done this or got any alternative solutions?
I had my bubbling rear near side arch repaired at christmas. Took a while as the guy made me a new wheel arch.
He ripped off the liners and threw them away as he said they cause more problems than prevent them. Once the repair was finished he coated both wheel arch edges with a black rubberised paint so it looks almost the same.
After careful consideration I have decided that I am going to run a “Group Buy” for my RearLinerSystem for AP2 owners. I am terribly sorry AP1 owners but I have just recently received drawings of the fender profile for the AP1 bumper from an owner who owns both and it appears that my design, modelled on my AP2 bumper, will not interface with the AP1 bumper profile in the bottom skirt area (the bumper is shorter than the AP2 and the skirt more truncated than on the AP2 which I did not know till now), so this will not mount properly in the fashion I had intended. If you want to try and modify the Liner, be my guest but I think it will only lead to frustration at what should have been. So in all honesty and with considerable regret and disappointment I can no longer, in good conscience, recommend this mod to AP1 owners. Of course, if you have already, or are in the throes of changing out your AP1 rear bumper for an AP2 (as a number appear to be doing), then I would love to continue to hear from you, if you are still interested.
I have posted the Group Buy details as a new thread under the Parts and Modifications Forum as that seemed to be the most relevant place to put it. Again my heartfelt apologies to AP1 owners who expressed interest in this venture - believe me I am as (or more) frustrated by this than you. Thank you for your interest.
mattc85
02-24-2017 11:37 AM
