Rear suspension question
Old 02-07-2010, 11:53 PM
Reco2k's Avatar
Default Rear suspension question
I have a strange noise coming from my rear passenger suspension, it sounds like there is grit in the actual shock when you go over the bump so i'm going to replace the rear shock and see if that works. I have found a pair of shocks off a facelift car does anyone know if these will fit without any problems?
thanks
Old 02-08-2010, 12:17 AM
loftust's Avatar
IIWU, Have a shifty around that area first to ensure it is not something else, a drop link for example. Try waggling the ARB around to see if anything moves/rattles. Failing that, wait 'til the Hants meet this week and I'll lend a hand
I would have thought that an MY04 shock absorber could have softer spring rates than your MY00...hopefully someone more knowledgeable than I will be along to confirm either way.
HTH
Old 02-08-2010, 12:22 AM
Reco2k's Avatar
Thanks, I have had a quick look and the top wishbone looks newer than the drivers side so i'm guessing it may have had a knock at some point in it's life it's just what else it might have affected that hasn't been replaced.
If you could have a look that would be brilliant
thanks
Old 02-08-2010, 12:35 AM
loftust's Avatar
No problem at all Reco...always happy to help
Old 02-08-2010, 12:54 AM
Garage R's Avatar
shocks are different between years i believe. They changed them along with the ARB's. Year differences are same as facelifts - 99-01/02-03/04>
Old 02-08-2010, 01:38 AM
Reco2k's Avatar
ok thanks i'll have to keep an eye out for some earlier ones incase it needs doing.
Old 02-08-2010, 01:58 AM
Fatbloke's Avatar
Loftus,
Would value an opinion on my own noisy suspension on Thurs if you fancy a quick spin?
I think it's noisy Whiteline drop links, but a second opinion would be good......
Any help gratefully accepted.
Old 02-08-2010, 02:03 AM
Squeak's Avatar
Loftust Says:
No problem, I'm sure we'll get to the bottom of it
Old 02-08-2010, 02:55 AM
Fatbloke's Avatar
Originally Posted by Squeak,Feb 8 2010, 03:03 AM
Loftust Says:
Wow. Has he become so busy on the forum that he's appointed you as a his PA?
Thanks very much anyway .
Old 02-08-2010, 10:18 AM
S2000Si's Avatar
what noise have you got fb?
Quick Reply: Rear suspension question
