Rear pads every 4k-time for a change?
I've just got through anothe set of rear pads in <4k should I go for ferodo 2500 instead, if i change to ferodo do I need to change the front as well.
The fronts are fine, I've only changed them once in 12k , I have never had rears go quicker than fronts on any other car that I've owned
I've booked it into Honda Mountsorrel for Monday, If the rears are sticking shouldn't Honda have picked that up when the oem pads were changed on the last 2 occasions.
I expect to get through pads as 80% of my driving in the S is cross country but 3600 miles is silly.
UK Moderator
Try going for a drive for a mile or two without braking at all, find somewhere uphill so you can coast to a halt, and then have a feel of the disc and wheel temperatures. If they are hot, then you have sticky or seized calipers.
