Rear light cluster differences
Hi all,
I wonder if someone would mind clarifying something as I can't find the answer via a search.
As I understand it, the facelift (LED) rear light clusters fit the pre facelift models unless I have been misguided.
Surely they can be a straight swap given the difference in voltage I would assume with an LED unit and the fact the fog light is separate on a pre facelift model?
The more modern units look much better in my opinion and may consider swapping if they aren't a pig to do.
Thanks very much.
Thanks very much.
Hi WRC
They do fit but requires some modification as the facelift lights have different fitment to the preface-lift so some cutting is require on the metals that holds the lights in order to make it fit, but its worth it as my mate have done it like you said the face lights does looks nice
1 Post
To fit the face lifted light to an earlier car you will need to trim some of the body work to get them to physically fit and the connectors on the back of the lights are a different shape/size. Also the electrical plugs are different, so they need some tweaking.
This is not a simple plug and play swap over job I'm sorry to say.
UK Moderator
You may find this useful: https://www.s2ki.com/...version-wiring/
and one for RHD: http://www.ozhonda.com/forum/showthr...ght-Conversion
iv just bought facelift front and rear lights i can take a pic of the connection if you want ? as people have said not the hardest job but need to dig out my hole saw remember to treat the cut section to some anti rust primer
Does anyone know if the inners of the front facelift lights can be bought separate, My indicator lens is cracked
