rear demister relay?
Hi still haven't got this sorted, has anyone got a demister switch I can try? As the demister switches are £70 new and £30 second hand, don't really want to spend that if it's not the switch.
Just a couple of ideas.
Have you checked with a multimeter to see if the power is getting to the demister screen. It is possible that the screen element is faulty.
Have you checked ( assuming you have found the relay ) if power is getting to the base. The easy way is to check continuity of the wiring loom with the meter on the ohms setting, but make sure the power is disconnected first.
Neil
Neil
I have both hard top and soft top and both don't work also there is a indicator light in the button and that doesn't light up as for the relay??? The slot that people have I shown for that there is no relay there not only is there no relay but there is no wires to that area even if there was a relay. The heated window worked when I got the car both hard and soft top worked also the light come on too in the button but now nothing. If I know where the relay is then I could at least test it but I really can't find it. It must have one somewhere because it worked previously also checked fuse and seems ok. Short of digging all the wired out I don't know where to find these items
