rear demist wiring
rear demist wiring
looking at wiring up my car with rear demist as it's been fitted with a glass rear screen (from the orginal plastic one). just no wiring has been sorted for it.
the connector tabs are there on the rear screen so it's a fairly straight forward job of wiring in power to it.
questions are:
- is there a standard loom for the s2000 that is pre-wired in, but i just need to add a fly-loom to the rear screen, add a relay, fuse and switch and be done with it?
- if not, whats the best way to route the wiring around the car? it LOOKS like theres a wire guide sewn into the roof to stop the wire getting caught when the roof is retracted. goes down the very back edge of the rear roof compartment.
- is the honda-fitment rear demist button just behind the cup holder on a 00my JDM, or is it on the dash behind the stalks?
any tips/tricks that might help me in fitting it?
questions are:
Have a read of this thread - half way down it talks about the demister!
https://www.s2ki.com/forums/index.php?showt...0&#entry9044268
I hope this helps!
I hope this helps!
ty gt.
looks like i might have to move the demist switch. center console on mine has a pocket instead of switch blanks (perfect size for mobile phone). and the dash has the aftermarket fog light switch in one blank, and the immobilizer bypass key on the other! doesnt look like i'll be able to use a genuine switch.
