Rear camber/geometry
Bit fed up and tired of the shonky handling of my S2K... I'd even go as far as to say the old astra was a better handling car than the S2K and that's saying something.
It's spun out on me a few times now at quite low speeds. It's very tail happy.
Not long had some part worns continental contisport contact 5's put on, All even tread 7mm across both tyres, same index ratings etc.
Here are my current geometry settings, front ends fine for grip really. As per all S2K's my bolts are seized... so need to know what I need to renew to be able to adjust the rear. I'll sort the fronts out at a later date...
Would upload a pic, but usual websites gone down...
REAR
LEFT:- Camber -2.53 Toe +0.24
RIGHT:- Camber -2.41 Toe +0.13
FRONTS
LEFT:- Camber -0.43 Caster 6.56 Toe 0.00
RIGHT:- Camber -0.39 Caster 6.53 Toe 0.00
Obviously the only thing adjustable was the front Toe ( big thanks to Ray )
Any help would be massively appreciated.
REAR
FRONTS
You need less rear camber and more front. 1.5 front and 2 rear is a good start. Also even toe each side will help although this isn't really the weather to test the handling of an S2000.
Oh and why are you putting part worns on? :S
Ah sound, I'd like some sort of setup where it will be a bit more neutral and predictable, rather than grip grip grip then let go.
I'll be brutally honest, I'm a tight fisted cnut, plus with future events that are out of my control mean I really have to watch my money at the moment mate.
UK Moderator
A lot of toe in gives you that grip, grip, grip and then let go thing.
Are those measurements degrees and minutes or decimal degrees or mm or inches?
Are you using OEM suspension?
A little less front caster may help as it'll slow the steering down which'll help you keep better control of the car.
I wouldn't run as much camber as Si suggests. A max of 1 deg at the front and 2 at the rear is fine for road use.
I THINK they're in degrees, Daytona Dave / Ray done them.
I am running standard shocks on Eibach Pro springs
Never understood caster, that makes sense, the steering is very twitchy and sensitive, quite unpredictable at times
UK Moderator
Right o, so I need rear adjustable toe arms? or is there a bit more to it than that?
Stiffer springs will make the car more tail happy (if they are indeed stiffer, that is). What rates are they front and rear?
For caster, think about a chopper motorcycle, the forks are at a very "flat" angle, making the front wheel along way away. That's what a lot of caster is.
A sportsbike has a lot less caster as the forks are closer to vertical.
As for the springs fella, I'll have to get some numbers off them, as they were already fitted to my car when I bought it.
BCA, I'll also have to get the Date code of them to find out for sure.
