Rear Callipers
Old 11-27-2014, 11:08 AM
rjkoneill's Avatar
Default Rear Callipers
Evening Guys.
Did a full brake refresh a few months back as my front calipers were sticking a little.
Only thing not changed was the rear callipers as my mechanic told me they were fine.
Enormous surprise as a fee months later, my nearside rear is sticking a little on a long journey home.
So time to refresh and hope it hasnt warped my expensive discs.
Looking to buy a pair of rear calipers.
Where is the best place to go? I got my fronts off eBay but the seller doesn't sell the rears.
Anyone got any advice on where to go?
Also, I haven't checked yet but worst case scenario, what to do if the disc is warped?
Old 11-27-2014, 11:23 AM
Toms1989's Avatar
Check the slider pins Firstly, They may just need cleaning up and re-greasing before you shell out on a new caliper.
If you find the caliper is sticking, pop into a local motor factors with these part numbers, they're bound to deal with at least one of these
Here are the part numbers for various remanufacturers:
Rears
AMK:-
RR LEFT TCA3069
RR RIGHT TCA3070
SHAFTEC:-
RR LEFT BC8896
RR RIGHT BC8896R
BRAKE ENGINEERING:-
RR LEFT CA2214
RR RIGHT CA2214R
All come with a 2 year warranty of 30000 miles, which ever comes first.
Old 11-27-2014, 11:31 AM
rjkoneill's Avatar
Very helpful advice. Thanks a lot.
Old 11-27-2014, 11:36 AM
UK Moderator
UK Moderator
lovegroova's Avatar
Tom was kind enough to have provided the advice above for the Forum Favourites Sticky: https://www.s2ki.com/...st__p__23172406 which you may find useful for other bits and pieces in future.
Old 11-27-2014, 11:58 AM
rjkoneill's Avatar
thanks, I am aware of that thread. my question was more aimed at what to do if my disc is warped.
Old 11-27-2014, 12:17 PM
DaGou's Avatar
buy a new disc....
actually
buy two new discs....
Old 11-27-2014, 12:26 PM
GreenmanS2000's Avatar
What he said
And pads....
Old 11-27-2014, 12:34 PM
rjkoneill's Avatar
Assumed that may be the case. Possibility if an expensive pair of Dixcels being junk doesn't fill me with enthusiasm.
Old 11-27-2014, 01:36 PM
UK Moderator
UK Moderator
lovegroova's Avatar
Sorry, hadn't spotted the warped question
FWIW, I had some seized rear callipers with a set of Dixcels and the discs were fine.
You could get them skimmed in the unlikely event they are warped (within limits of course). Shouldn't cost much.
RobAp1's Avatar
Without jumping to conclusions, I'd get the calipers replaced and make sure the pads haven't been cooked. If they're crazed or starting to crumble then they're junk but if they look alright I'd put it all together and see how the pedal/car feels and behaves under braking. If there's no judder then you're obviously good to go.. Depending on the amount of heat that got into the pads, I'd look to replace them as a precaution. The rears aren't all that great at dissipating heat in my experience
Quick Reply: Rear Callipers
