rear bump steer
rear bump steer
im thinking of lowering my car on some spoon springs and just been reading up on rear bump steer, ive noticed a couple of different kits and just interested what the difference were and do they do the same thing? i looked at the hard race kit which are toe arms and the spoon kit which are bump stops. confused?
on just lowering spring you should not need them unless you then run low offset wheels and lots of camber,
with a relatively stock set-up camber/toe and caster wise you should be fine,
probably worth a call to dixon to see what his opinion is, he will also be able to sell/fit any parts you may need and do geo set-up
s20004lifehomes
Member S2000 Classifieds and For Sale
20
04-25-2010 11:36 AM
