Ratteling clutch on lift off.
Old 03-06-2010, 12:40 PM
Suits's Avatar
Default Ratteling clutch on lift off.
I have a issue with my clutch on lift off (decleration), when the car is left to decelerate in gear the clutch seems to give off a rattle. Clutch plate maybe?? Depressing the clutch makes no diference, so I have rueled out the release bareing.
As soon as you put some drive through it, the noise goes.
Apart from that the clutch seems fine, a little bouncy in 2nd after initial engagement at low revs, but it seems fine.
I dont really want to change it as it not a drivablity issue, its just a little annoying.
The car has done 57,000 miles and is still on its original clutch.
Old 03-06-2010, 01:09 PM
loftust's Avatar
I suspect you have clutch buzz, which almost every MY99-MY01 has, it's normal.
HTH
Old 03-06-2010, 01:21 PM
Suits's Avatar
HTH
Cool.
That does help mate, cheers. Rests my mind a little if it's common.
Is there a cure for clutch buzz?
Old 03-06-2010, 01:26 PM
CHIPPO's Avatar
Mine had a new clutch under warrenty for this 8 years ago,m with anew 055 unit which was supposed to be the cure, still does it. to a slightly lesser extent
Old 03-06-2010, 01:43 PM
S2000RJ's Avatar
HTH
Yes, is normal, unless the clutch was updated. Took Honda a few attempts to get it right. Some had the first fx, then needed to get that replaced a few months later! If gear change is still fine after all this time, is probably safe to ignore it.
Old 03-07-2010, 02:11 AM
Dembo's Avatar
Mine doesn't do it at all since the clutch (and gearbox) was replaced.
There doesn't seem to be any negative consequence to the clutch buzz, it's just a little annoying.
mohamaddoski
10-17-2010 07:42 AM
Gh0ztt
02-18-2008 06:43 PM
DFul4d
07-30-2003 06:40 AM
Quick Reply: Ratteling clutch on lift off.
