Raising Car onto Axle Stands
I like to jack front individually then the rear off the diff. Then reverse when lowering.
The saftest way on a lowered car when you can't reach the front central jack point IMO
On a lowered car it is easy to drive onto a couple of planks of wood just to get the front high enough to get the jack in to the centre lifting point. I have some small home-made ramps made out of a series of increasingly short lengths of wood, to get the height at the front.
Sorry for the lack of graphics skill, but the principle is like this:
UK Moderator
I have a 3 ton Costco bought jack that has a good long reach. With my lowered car, I drive one front wheel onto a 2cm paving slab and the jack goes under to the central jacking point easily.
Review of it here: http://www.eunos-roadster.co.uk/?p=856
Banned
Originally Posted by AlexGJ248' timestamp='1352043470' post='22128697
I usually just jack it up on the bottom of the wishbone (as close to the wheel as possible). Then put the stands in.
I pulled a car of an axle stand onto my chest. Fortunately it was the rear of an EK4 so the weight was probably in the region of 200kg. Still, being pinned under a car and not being able to move or breathe with your mate screaming thinking you're dead is pretty scary!
If you can, put the wheel you have taken off, under the car near where you are working
I wouldn't say stupid, most are probably just rushed. Im always careful because im a little paranoid about it so axle stands, old wheels underneath and the jacks on front/rear points if i can as well. Cant be too careful unless of course you can bench half a ton.....
When I put the axle stand on the Civic, it was in the specified place to put it according to Honda. I wasn't rushed either.
Bottom line is I didn't weigh up the situation properly primarily because I was busy concentrating on other things. Having something that is sold and can't topple means that whatever happens, you are giving yourself a good chance of coming out of the issue alive!
Within two minutes of getting out from under the car, I had to get back under it to finish of the work. I put a brave face on at the time, but I was fecking bricking it TBH, despite putting several axle stands underneath!
Originally Posted by Irish TuneR' timestamp='1352280812' post='22134888
[quote name='gaddafi' timestamp='1352202313' post='22132427'] I've known two people crushed to death under cars - absolutely stupid way to die.
[/quote]
I've got four new axle stands and two jacks - one of those jacks is the costco 3-tonne jobbie so I'm fairly confident the equipment will sustain the load. However getting underneath a car, you've always extremely wary of what's actually happening and the type of mass above you. Well that and how little time it would take for you to end up looking like a pancake.
Getting under the car is nerve-racking period. When it's not, it's probably time to re-evaluate what you're up to as you may not be concentrating.
