Quick roof noise question
Old 02-10-2006, 09:41 AM
PhenomS2k's Avatar
Ah ok, iv put the tubing on the hooks themselves and it pulls far tighter and reduces wind noise massively.
Old 02-10-2006, 09:46 AM
NNervous_R's Avatar
[QUOTE]Bibbs Posted on Feb 10 2006, 01:17 PM
Old 02-10-2006, 11:03 AM
wampa's Avatar
any pics?
dont really understand!
Old 02-10-2006, 01:00 PM
Administrator
AquilaEagle's Avatar
You could buy new strikers (is that what they are called??) the metal bits that the hooks hook into - you'd be suprised how much they wear down.
Shipley's Avatar
Originally Posted by Zeemz,Feb 10 2006, 01:25 PM
Sounds like your roof strikers are worn.... There was a TSB for MY00-01 to replace the strikers with hardtop strikers.....
I fitted a hardtop last week and the day the fixing kit was put on the car - the strikers were also replaced. Coming home with the soft top up, the car was noticeably quieter.
I nearly didn't bother giving the strikers to the garage as mine looked fine.
Old 02-10-2006, 02:04 PM
tebs's Avatar
Originally Posted by Cardiff,Feb 10 2006, 02:55 PM
Thanks for TSB, I have hard top strikers though! Will check for wear and get some type of rubber tubing to pull the parts closer
they are the strikers i sold you. they were ok for wear.
i had the same problem with the strikers on my car. i sorted it by making up thin metal shims about 3mm thick 9mm wide and 14mm long. i stuck them in the striker gap with double sided sticky tape where the hook would come into contact with them. this provided enough tension to stop the roof rattling. i tried the rubber hose fix but this only lasted about 2 days before the hook pierced through it becoming lose again. no rattles 8 weeks after mod.
Rob88
12-13-2010 06:43 AM
SoichiroUK
05-28-2007 03:46 PM
Chris R33
08-18-2006 11:12 AM
Purple Haze
09-19-2004 10:07 AM
mikey k
08-16-2004 02:18 AM
Quick Reply: Quick roof noise question
