Question on Nuburgring
Old 07-20-2005, 11:05 AM
Chris888jj's Avatar
Default Question on Nuburgring
Quote from August 2005 issue of EVO: "...Remember whose car it is and that you may want to drive home in it - the Karussell is so rough that unless you take care, it can destroy your suspension and drivetrain."
I'm contemplating a trip to the 'ring for the first time, and therefore this statement concerns me. Has anyone here been there and could comment on driving this corner in an S2000? If true does this apply to mini-karusell as well? Is the solution to avoid the rough part altogether? - btw my experience so far has only been on the playstation.
Thanks, Chris
Old 07-20-2005, 11:15 AM
LLOYDJ's Avatar
July meet
https://www.s2ki.com/forums/index.php?showtopic=279973
Old 07-20-2005, 11:16 AM
LLOYDJ's Avatar
https://www.s2ki.com/forums/index.php?showtopic=280674
https://www.s2ki.com/forums/index.ph...ic=250916&st=0
https://www.s2ki.com/forums/index.php?showtopic=279209
Have a look at links above!
Karussell is fine just hold on tight
GTFCTIM's Avatar
Solution is to drive as fast as you can around it
Have a look at the vid in my sig and you should see how rough it is.
Old 07-20-2005, 11:20 AM
GTFCTIM's Avatar
Suppose i'll have to put up a pic of me on it too
Old 07-20-2005, 11:29 AM
mikey k's Avatar
Karussell picture
Looks good - I should get my ar$e over there to!
Old 07-20-2005, 11:46 AM
Chris888jj's Avatar
Thanks for the links and pics guys - doesn't look too bad in the video, I guess the idea is to avoid getting the tail out at all while on the rough stuff. Right, now to get back to training on GT4...
Old 07-20-2005, 11:47 AM
Chris888jj's Avatar
Old 07-20-2005, 12:33 PM
Kobe's Avatar
Originally Posted by mikey k,Jul 21 2005, 04:29 AM
Karussell picture
yep.. petrol head heaven..
Karussell is not the most difficult corner on the ring.. and in terms of rough ride..there are much worse roads
Old 07-20-2005, 01:07 PM
GTFCTIM's Avatar
If you get the tail out on the Karussell then you will be into the armco.
It was fun getting very sideways as I exited it on one lap. (It was actually just after the pic was taken that I posted above).
Quick Reply: Question on Nuburgring
