A-pillar gauges
A-pillar gauges
Hi
I am thinking of putting a A-pillar gauge pod in,I am not sure what gauges to put in yet Any susgestions?
I like Spa gauges and Dakota digital gauges
Dakota tire pressure and temperature gauge
Kev
Kev
Hi san2000
$399.95
Monitor tire pressure from inside your vehicle with Dakota Digital's new ODYR-22-1 tire pressure monitoring system. 2-1/16" gauge displays pressure in all four tires. With the press of a button, you can also see the internal temperature of each tire. Sensors mount inside wheel with metal band for secure and reliable fastening. All necessary sensors included.
$399.95
Technical specifications
Minimum operating voltage - 7 volts
Maximum operating voltage - 18 volts
(operating at or near maximum rating for an extended time can damage unit)
Maximum pressure reading - 78 psi
Gauge Resolution - 1 psi
Pressure Accuracy - 2 psi
Temperature Accuracy - 2 F (3 C)
Typical current draw (@ 13.8V) - 0.25 A
Originally posted by AquilaEagle
I'd prefer something like those -----^-^_^__^___^ ___ machine things that beeps in a hospital, would look far more cool
Jumpstart it when you flatline!
