Petrol
Old 01-25-2002 | 06:49 AM
Lotusman's Avatar
Default Petrol
Quick question....does the S2000 need Super unleaded (both old and 2002 model)
What sort of MPG do you get ?
Old 01-25-2002 | 07:04 AM
AATees's Avatar
I believe Honda states that the "S" requires 91 octane gasoline. However, the timing/ignition system will advance/retard the spark to take advantage of higher octane fuels. I typically run Shell Premium 93 octane unleaded fuel.
Remember, in the States we quote average octane values (average of Motor Octane & Research Octane). Without getting into the differences, for conventional refined and blended gasolines the Research number
Old 01-25-2002 | 07:20 AM
UKjasonm's Avatar
SUL is recomended for the car but it will run on normal 95 Ron premium. I find it runs smoother on SUL (97 Ron) and in particular Optimax (~99 Ron).
Old 01-25-2002 | 07:40 AM
Mole's Avatar
I normally fill up with 97ron or optimax, normally costs me about
Old 01-25-2002 | 08:53 AM
composite guru's Avatar
If you look inside of your filler door it should tell you to use min 98RON fuel (mine does anyway)
Old 01-25-2002 | 09:15 AM
Frenchie's Avatar
[QUOTE]Originally posted by AATees
[B]I believe Honda states that the "S" requires 91 octane gasoline.
Old 01-25-2002 | 09:47 AM
Turtle's Avatar
Don't want to be too picky here, but firstly most UK cars have F20C-2 engines which Honda recommend 98 octane. Lower octane for short term emergancy use only.
-Brian.
Old 01-25-2002 | 10:07 AM
AATees's Avatar
Sorry for my dated information , the EU did indeed phase out leaded gasoline in 2000. Since my buddies with Caltex in Hammersmith were made redundant, I have lost track. We worked together to build a gasoline blending plant in 1995-6, and I was told it was still operating. They must have closed at least one valve.
It is still surprising that the EU took so long. I wonder what my father (lives near Oxford Circus) is doing to fuel his old V-12 Daimler.
Old 01-25-2002 | 10:15 AM
Frenchie's Avatar
[B]Sorry for my dated information , the EU did indeed phase out leaded gasoline in 2000.
Old 01-25-2002 | 03:06 PM
Kobe's Avatar
I am lucky to get 20-22mpg from my JDM model with 100octane - must be the way I drive, but fortunately I'm managing to get the premium fuel for 50p a litre so it's not so bad I guess.
Quick Reply: Petrol
