part numbers
part numbers
search feature down..
if anyone could help on these part numbers would be grand..
sorry just don't trust my local dealership.. and none of the sites which offer exploded diagrams seem to work..
MY04 OEM parts:
- oil filter
- oil filter wrench tool
- air filter
- head cover gasket set
- sump crush washer
- gearbox crush washer
- diff crush washer
- rubber bung which sits on hard top rear bracket to act as bump stop against soft top
MY04 OEM parts:
- oil filter
- air filter
- sump crush washer
- diff crush washer
UK Moderator
Not my line of work at all, but all things hifi have been a hobby of mine for 20 years or more.
I now know enough to know what's a load of rubbish and what isn't, as well as an understanding that there's no real point in going too crazy in a car as inherently noisy as an S2000.
Too crazy is, of course, relative.
But either way, I'm happy to help if I can, and I'll admit when I don't know the answer.
oil filter - 15400-RBA-F01
- oil filter wrench tool - Halfrauds or equivalant
- air filter - 17220-PCX-Q01
- head cover gasket set - 12310-PCX-010
- sump crush washer-94109-14000
- gearbox crush washer-94109-12000
- diff crush washer-94109-20000
- rubber bung which sits on hard top rear bracket to act as bump stop against soft top - Don't have a clue.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
UK Moderator
I checked the other parts for you aswell.
Some of the part numbers quoted above are not correct.
The correct part numbers are:
- oil filter 15400-PCX-004
- oil filter wrench tool 07912-6110001
- air filter 17220-PCX-003
- head cover gasket set 12040-PCX-305
- sump crush washer 94109-14000
- gearbox crush washer 94109-14000 and 94109-2000 (one for drain and one for fill)
- diff crush washer 90401-PCZ-003 and 94102-PCZ-003 (one for drain and one for fill)
- rubber bung which sits on hard top rear bracket to act as bump stop against soft top 86445-S2A-000
Chris.
Chris.
