Paint on my car
Originally Posted by mattg4321' date='Jan 2 2009, 12:45 AM
nooooo noooo nooooo! and no to t cut too
Claybar might work, so I would suggest that first, if you're going to try and sort it yourself.
However, I would be going after the knuts that did the damage in the first place, to be honest.
Hope you get it sorted without too much hassle, Peter.
Thanks for all the advice
The ejit who painted the fence was an agency labourer hired in by the same company I work for, so rather than kick up a fuss I might as well try and sort it out myself.
The paint spots come off if I rub them with my nail, but there are thousands of them all over the car, so that would take forever.
Think I will give the claybar thing a bit of a go. Have done a few searches and it sounds like it might well do the job, and it's about time the paintwork was given more than just a normal shampoo wash anyway. I just hope I don't end up doing more damage as I don't know much about this detailing lark. Will wait for the temperature to lift a few degrees first though
I was told by TM that claybar can remove factory paint overspills, which i image are very minor so id say go for clay bar.
Using clay is very easy, like matt said check out you tube.
I'd try cellulose thinner (any bodyshop sells it) first. But be careful if Chipsaway have already ruined any areas of your car, because thet will wash off too.
Claybar out of stock in our local Halfrauds (typical), so I will have to wait until next weekend before giving her a going over
Looked on youtube and they used liquid clay. What's the thoughts on this as an alternative? Is it as good as claybar? It seems to be easier to use.
Well, Halfrauds finally got the clay kit in stock yesterday, so I have started the task (only done the HT and bonnet as bad light stopped play). The clay is definitely working although it takes a lot of passes to remove the paint. Spent about 3 hours so far.
Well impressed with the smooth feel of the bodywork compared to how rough it felt before. I never realised how much crap must have been caked on that normal washing alone doesn't shift. I'm liking this clay stuff, although it is time consuming
Any suggestions on treatment after I've finished claying? Just a coat of wax?
