..Pacing up and down
Old 02-04-2010, 05:40 AM
  #21
J_D
J_D's Avatar
Sorry Andy, Id think you'd rather know now than later on.
Punchdrunk - When your bush cracks and fails, because its been twisted, and your upside down in a field, would it matter to you?
Old 02-04-2010, 05:47 AM
  #22
punchdrunk's Avatar
Fair enough, I hear you.
Old 02-04-2010, 05:53 AM
  #23
mikey k's Avatar
[QUOTE=punchdrunk,Feb 4 2010, 03:34 PM] If the bushes are seized but the geo is within range, what does it matter
Old 02-04-2010, 05:57 AM
  #24
andy2000's Avatar
Fair nuff J_D. I know there are a lot of cowboys out there.
But how would someone like me who can just about change a spark plug, have any idea that was the case.? I'm hoping TGM are OK, they seem to have a lot of good press on this forum. And I would think that if they were actually seized they'd tell me as they'd want me to spend the £££ with them to get them unseized.?
Guess we all have to put our faith in the experts sometimes.
Old 02-04-2010, 06:02 AM
  #25
Rob88's Avatar
Most of the advice I’ve got on the subject led me to the conclusion that I’d get all my bots removed, greased and replaced.
The hassle of having a stuck bolt seems to outweigh the cost of getting them greased.
Prevention is better than cure.
Old 02-04-2010, 06:10 AM
  #26
UK Moderator
UK Moderator
lovegroova's Avatar
Andy,
If it's seized within range, it may mean that the camber is "stuck" at, say 1 1/2 degrees negative, which means it's in range. What TGM can then do, is match the other wheel to that figure, meaning all is fine.
If you wanted, say, 2 degrees each side, then they wouldn't be able to do that for you. Inother words, you're restricted to whatever setting the seized bolt gives you.
However, if the bolt was seized with, say, a positive camber setting, which would be well outside parameters, then it would require removal.
Hope that's clear.
Old 02-04-2010, 06:38 AM
  #27
andy2000's Avatar
[QUOTE=lovegroova,Feb 4 2010, 04:10 PM] Andy,
Old 02-04-2010, 06:42 AM
  #28
UK Moderator
UK Moderator
lovegroova's Avatar
All the settings are interlinked I think (although I'm walking on thin ice here).
If you sit in the car, the camber will change as the suspension is compressed, so I suppose if you alter the camber on one side, it affects the other slightly with the change in height.
Someone more knowledgable will be along shortly, I'm sure.
Old 02-04-2010, 06:50 AM
  #29
oxhouser's Avatar
The bush twists all the time in use, all the suspension movement is through the bush twisting, the centre tube stays still, so if its stuck in the correct position no problem
if you meant the mechanics had twisted it and damaged it then ignore me
  #30
punchdrunk's Avatar
Originally Posted by andy2000,Feb 4 2010, 03:38 PM
Yep, thats exactly what they have done. Both now set to -1.50.
oddly enough the rhs was at -1.40 to start with.
lhs was at -1.80 to start with but when they moved it to -1.50 then the rhs went to -1.50 too.
Does that sound right ? Tom did explain how it would do that but it all got a bit scientific for me !
Did you get a before and after print out? Are you prepared to scan a copy and upload it?
Here's mine;
Quick Reply: ..Pacing up and down
