Ok I need help!
Ok I need help!
Hi guys, I need help, I have been trying to change the speakers in my new s2000 but that's a story for another day. Lol
The first problem is that I didn't get it finished and had the windows down and the door trim off on both doors, so I plugged the drivers door window switch in, thinking I could do both windows up with that switch, but when used the switches the drivers window went up as it should but the passengers window didn't move so I thought it mite be that the other switch wasn't plugged in so I plugged it in, tried it, nothing. I evan checked the passenger window lock switch and it's not that because I could hear the relay clicking (I think) o and in my anger i broke the passenger window switch witch made it worse so I give up lol.
Please help!
Please help!
Pull passenger door card off. Check everything is plugged in and the right.
If the button is broken then use the driver side switch.
If this doesbt work. Make sure the window switch on the drivers side is actually turned on to allow the passenger to do their window up and down. This switch is mounted sideways infront of the window things (I think) play with that. Actually try this first.
hope that helps fella.
mike
mike
