Oil temp Gauges
Oil temp Gauges
Morning all.
Looking at an oil temperature gauge for the S as I am planning on doing some track action in the near future and would like to keep an eye on things.
I'm not overly keen on the idea of drilling and tapping into the sump so thought about sump plug senders.
Anyone had much decent experience with them? With the old Astras and 2.0 Turbos they weren't said to be accurate due to being the lowest and coolest point in the sump.
Is this true?
regards
Tom
Is this true?
regards
Tom
ive got one from demon tweeks. its great, but dont overtighten. Id also recommend changing it regularly.
^ free plug alert ^ also i have an aem temp gauge and sensor for sale ;>
I have my sensor in this location but it gives dodgy readings. When travelling fast the temperature drops way too fast for it to be accurately measuring the oil temperature. I did notice when fitting it that the sender doesn't have much room around it for the oil to immerse the sender. I have another adapter that i might drill out abit where the sender sits and see if that makes it any better. I think its measuring the sumps temperature rather than the temperature of the oil
What sort of oil temperatures are you reading at the sump? I reckon my sender has maybe less than 0.5mm of a gap for the oil to go around it.
