Oil advice and recommendations from OPIE OILS
#121
Thanks for the reply Si2k.
Thats a relief as I'm sure most people keep a certain amount of oil in an opened container for topping up etc.
I know my local Honda dealer store Castrol oil in an opened 45 gallon drum.
Is there a recommended use by period for opened oil? Castrol give you the made by date but not a use by date!
Thanks
Michael
Thanks
Michael
#122
what options do i have for a slightly modified car that is used for occasional hard track use?
Is Castrol Edge Sport suppose to be better than the normal Edge? If so, why is the normal Edge more expensive on your site?
#123
Originally Posted by Si2k,Feb 1 2009, 04:37 PM
I have suspicions that a 0W causes issues with the Timing chain tensioner on the F20C, causing it to rattle.
I always got on well with Mobil 1 before, but my new engine likes to drink it a lot more. So, without getting all anal about it, is there a simple answer to which oil to buy that will last?
#124
Originally Posted by Dembo,Oct 16 2010, 12:44 PM
I found something on this site saying Mobil 1 would tend to cause the timing chain rattle through not being thick enough. Personally I figured that was , but it has to be said, I only started getting the traditional timing chain rattle on mine after I changed the oil for 0W40 Mobil 1.
For me, all of the fully synth edge (bar the 10/60 which i havent used) was about the same.
I did try the silkolene pro stuff, but it wasn't as long lasting.
I won't change from edge though.
johninator
04-11-2004 07:48 PM
