Oil
Oil
Search is buggered for me.
The FAQ for oil tells me what to use to run in but not to use afterwards.
Do I just need some 10w40 fully synthetic from a decent brand?
Member
Is it for top up or an oil change?
What's int here atm?
There's no real right or wrong, but my advice would be a named brand fully synth 5w40 or 10w40, or Castrol magnatec if you don't track the car.
All oils mix, so whatever you top up with will be fine.
If you dont know what is in there then 10w-40 semi or full synthetic will be fine, if you want to go better top up with 5w-40 synthetic.
Cheers
Guy
Cheers
Guy
I was told to buy Shell helix by Honda (which was actually cheaper than Castrol magnatec from halfords )...so i did! the bottle came in a little leatherette pouch and disposable gloves, funnel, the works...first time Honda havent tried to rip me off
