Oil
Slightly above - that will be fine. It must only be slightly though. Don`t really overfill a lot.
If it is a lot over, you are best dropping some by releasing the sump plug. Then refill from above as normal.
It includes destruction of the cat convertor and can result in general engine problems/destruction(!). It's best to be very sure about it.
If you feel it is a lot over, don't drive it. Drop some oil.
i added a litre without really checking it before, just thought "haven't put any oil in for a while" ... so it could'nt really me more than half a litre extra, is that alot ?
Originally Posted by Spuffington,Aug 3 2006, 12:49 PM
Surely if you let some out of the sump plug you'll need to replace the sump gasket?
Just drop the sump plug - not the fecking sump!
Worst case you replace the washer on the plug - but that's not always needed.
Originally Posted by cheshire_carper,Aug 3 2006, 12:58 PM
Like I said, if it isn`t too high, you'll be fine. If you really are not sure and it could be a litre over, def do not drive the vehicle.
