o2 sensor problem
Old 07-16-2011, 03:45 AM
Daren 83's Avatar
Default o2 sensor problem
decided to put my cat back on as its due for mot. cant get my old sensor off the decat. so ordered one from local motofactors. and the one i got is one with a male end with pins. as u know its a female end which i need. and thats all they had listed. now heres problem. ive tried everywere to get one and everytime i ring they say they cant find one on there database??? spoken to honda up and i dont really wanna pay nearly 200 quid for one. any help?
Old 07-16-2011, 03:54 AM
loftust's Avatar
I'd remove the decat from the car, and unplug the sensor, allowing you to remove both items at the same time.
Once it's on the deck, you can use a spanner and a hammer to remove the O2 sensor.
Old 07-16-2011, 04:10 AM
Daren 83's Avatar
ive tried everything to remove the sensor. wont come out at all. so need to get a new one. just find it strange why local motfactors dont have it listed????
Old 07-16-2011, 04:16 AM
JonUKS2000's Avatar
I couldnt remove mine from the cat, so i cut the wires, removed the cat. Then i used a blowtorch thingy, heated it up, and it eventually came undone.
Wasnt easy, but its do-able.
Old 07-16-2011, 05:37 AM
Daren 83's Avatar
Already tried that. Used oil. Heating it up etc.not budging at all. Isn't there anywhere else apart from Honda that I can get one from? With the female clip?
Old 07-16-2011, 06:18 AM
loftust's Avatar
Irvatron has posted where to get these from...a search should help you out
Old 07-20-2011, 04:51 AM
Daren 83's Avatar
This is puzzling me??? Can anyone confirm that the sensor that goes into the cat.that the end of it is a female or male connection? Cause.the 1st one I got from local motofactors had a male end. And now I've got a genuine Honda one with male end. But the one that came off my car had a female end? And obviously male and male won't connect???
Old 07-20-2011, 05:50 AM
Daren 83's Avatar
do i actually need this sensor. if im running a mugen ecu???
Old 07-20-2011, 06:47 AM
Daren 83's Avatar
anyone?
Old 07-20-2011, 07:40 AM
s2konroids's Avatar
This should hopefully clear things up.
There are 2 sensors.
1st 'primary' at the start of the CAT and 2nd 'secondary' at the end of the CAT.
In 'simple terms' the primary controls fuelling through feedback in real time if the AFR (air fuel ratio) is rich or lean and adjusts - so the mugen ECU definitely needs this or the car would run like a bag of crap.
The secondary in simple terms just checks if the CAT is working/is still there.
Lastly look up 'walker' o2 sensors by me and 'grittyshaker'
I dont know which one you need, but i think the secondary is female.
Quick Reply: o2 sensor problem
