Noisy roof blocks out Val Doonigan CD
Ive just bought a Jap import. The noise from the roof is so bad you cant hear each other speak. Ive checked with Honda who tell me that the UK models were re-called for new clamps fitting but they wont do it for a Jap import. Has anyone had a similar roof problem or difficulty with Honda for recall work ? Ive had to bin my Van Hooligan CD's
I have a Jap import and the catches rattle. Not as much as yours by the sound of it.
Coincidentally, this weekend I was going to take a look and see if I can sort them out.
I figure a gentle cuddle with a large pair of pliers should suffice
I think there is a plate beneath the catch which may also rattle so that might be worth looking at.
My catches used to rattle as well - it was the metal plate on the underside of the catch.
When I unclamped the catch I tapped the metal plate with my finger and it would make a noise - to stop it I stuffed a bit of folded paper in-between the metal plate and the outer plastic casing - I haven't had a problem since.
Originally posted by pennine
its not the rattle its the wind noise thats a problem. anyone know if they are adjustable.
Edit: Here it is - https://www.s2ki.com/forums/showthread.php?...threadid=108429
- Adam.
I was bothered by all manner of roof noises last year.
Rattling catched, wind noise - the lot.
Went to dealer twice.
In the end, a shitload of Vaseline around all of the rubber cured it all. I was amazed.
Try everything!
Try everything!
Just one comment - better to use a water based liubricant such as KY Jelly as vaseline can perish rubber, as happens with other rubber/latex based products, ahem....
