Noises
Noises
Hi,
The engine is cold here, but does this sound ok or early tct?
https://youtu.be/bmvOeXqpGz0
Also when I start the car relatively quickly after its first cold start i.e. moving out of garage, turn off, shut garage. Restart, it makes a grinding type noise on ignition, any ideas or is this normal?
Thanks
Joe
Thanks
Joe
Thanks, will try again when hot. Just read up on TCT and you hear whats not there yourself!
Any ideas on the grindy noise upon reigntion? Will try and record that next time.
UK Moderator
The starter motor sometimes gets a bit sticky and doesn't disengage properly. That'll be what that is. It's pretty common, especially in colder temperatures, and nothing to worry about, really.
Originally Posted by richmc' timestamp='1426371145' post='23540192
The way to stop the grinding noise whilst you close the garage is to .................................................. .......... Leave the engine running.
