No tail lights HELP!
Old 07-07-2013, 12:11 PM
Vixen's Avatar
Default No tail lights HELP!
Driving home last night stopped at lights and told by guy in 4x4 that I had no tail lights, brakes fine drove home fast!
Fuse for rears also cover stereo etc that are all fine
I've recently had respray so bumpers would have been off, anything obvious I should check before ringing garage??
Old 07-07-2013, 02:02 PM
mdb_75's Avatar
Maybe they've left a connector unplugged.
It could be something silly though like both bulbs have blown, have you checked them and are the number plate lights working?
Old 07-07-2013, 02:35 PM
Vixen's Avatar
Number plate working, would be odd that they had both blown, am thinking something not connected properly, just don't know what to check
Old 07-07-2013, 03:10 PM
Deadly Aura's Avatar
Id take the covers off in the boot, and have a look to see if the connectors are connected to the light clusters. If not, then swap bulbs to see if its them, if its neither of them then Id say it could be an electrical problem. Maybe linked to it being worked on or just a coincidence.
Old 07-07-2013, 10:23 PM
Joeh's Avatar
Yeah as mentioned very simple to check, boot lining behind the lights are easy to remove, just pull them back and look for anything unplugged.
Where are you based? I can have a quick look if you're close
Old 07-07-2013, 10:25 PM
unclefester's Avatar
Carrie - just peel back the carpet trim from behind the lights - will be instantly obvious if they're not connected up
Old 07-07-2013, 11:40 PM
Vixen's Avatar
Thanks all, just checked boot and looks like all plugged in ok will be calling garage
Old 07-08-2013, 12:09 AM
GreenmanS2000's Avatar
Do your brake lights work?
Old 07-08-2013, 12:13 AM
Some quick checks
Reverse lights?
Hazards?
Indicators?
Foglight?
Or are they ALL out.
All out can't be lamps / bulbs - that'd be dead unlucky - smacks of something not connected or a fuse blown. Taking it back is the right thing to do i think
Old 07-08-2013, 12:18 AM
mdb_75's Avatar
From the first post the brake lights are working.
Have you checked the tail light bulbs yet?
Quick Reply: No tail lights HELP!
