Nitrons are go!
Old 09-14-2005, 12:45 PM
  #61
mikey k's Avatar
Thought it was Guy?
Am I being realistic doing a DIY install?
I'm wanting to strip and grease the alignment bolts at the same time so seems sensible to do it all in one go!
Old 09-14-2005, 12:49 PM
  #62
eSeM's Avatar
Shouldn't be a problem.
Old 09-14-2005, 12:52 PM
  #63
mikey k's Avatar
How's yours going Steven have you got all your bolts sorted?
Old 09-14-2005, 01:03 PM
  #64
eSeM's Avatar
All the rear bolts that were seized have been sorted, both wishbones and one control arm were replaced. Fronts were OK.
I am getting the alignment sorted tomorrow
Old 09-14-2005, 01:08 PM
  #65
Paper Lawyer's Avatar
Originally Posted by mikey k,Sep 14 2005, 09:45 PM
Thought it was Guy?
Guy is Md, Pete is chief engineer. Speak to Guy in first instance.
Old 09-14-2005, 01:12 PM
  #66
mikey k's Avatar
time to test it out then!
What sort of drop are you working on?
Can one of you two explain stagger to me! (not the pi$$ed type )
Old 09-14-2005, 01:14 PM
  #67
TBH, not sure. I'm now 625mm at front, 645mm at the rear. Measure the height of your own wheel arches for compariosn
The stagger is the difference between the front and rear ride heights. As you see above, I have a 20mm difference. I think OEM is 30mm, but I'd have to double check.
Old 09-14-2005, 01:24 PM
  #68
mikey k's Avatar
I presumed that's what it was IIRC Turtle suggested keeping the OEM stagger.
So corner weighting must involve making sure the ride heights are equal either side rather than weighing each corner
I can see this will be a bit trial and error until you get them even.
Do the adjusters lock up really well on these? I can also see the alignment going to $hit if one moves!
Have you found they "settle" at all ie need readjusting after a week or so?
I'm contemplating fitting it all getting the ride height thereabouts and driving (carefully) round for a hundred miles or so. Then checking the heights and getting the geo done.
I'm a bit concerned the geo may move the ride height and I may end up chasing geo and ride height alternately until I get it spot on.
You guys have both gone for around 20mm drop?
Checked with a search 30mm seems to be the limit with correct alignment before drop links need changing.
Old 09-14-2005, 01:30 PM
  #69
No, corner weighting involves putting your middle finger up at matching heights and instead adjusting so the weight is even on the four corners (fancy scales under each wheel). Ideally you ge tthe hieghts matched up as well, but that's unlikely.
Old 09-14-2005, 01:32 PM
  #70
Yes, I wish I did that. I need to get my geo redone as I raised the front end 10mm since geo was redone.
Quick Reply: Nitrons are go!
