Newbie tyre question
#31
The only difference I can see is that the F1's are slightly smaller on actual "tread width" for the same section width but Id put this down to the fact that the S02's are a squarer tyre and the F1's shoulders run off.
I did find an interesting Tire rack review more so for the T1R's than the F1's
http://www.tirerack.com/tires/tests/...ay.jsp?ttid=69
#32
at 311 a set I'm gonna stick some F1's on over winter, and if they aren't up to so2 scratch then put them (so2) on after winter again! GSD3F1 get extremely good write ups and feedback in pretty much all places u look. Ultimately I don't expect them to be quite as good/stiff/responsive as so2 for dry sunny hot days, but over winter I expect them to be better when braking/handling on wet surfaces. Not that I drive stupidly on wet roads, no one should, but in an emergency situ you want all the grip u can get.
#34
Originally Posted by Lickermat,Dec 1 2006, 12:22 PM
According to Goodyear in the UK the 225 x 50 x 16 tyre is within spec of the S02 on OD and section width. I could be wrong but my understanding was the section width that was the issue on other 225 sized tyres which for most they are smaller than the so2 rears.
#37
I've got some on order as well, I'm hoping its a good choice for the winter.
Despite there not being quite as much rubber contact as the so2 due to bigger rain channels on the gsd3, I think/hope the gsd3 benefits for wet/slimy roads will outweigh the negs. I'll post up my thoughts in due course.
#38
You can fit 225s on the rear if you want but be aware that you will have less dry weather grip at the back.
mebz
05-16-2004 09:42 AM
