new noise coming from the wheels
Old 03-04-2006, 04:20 AM
nickrg3's Avatar
Default new noise coming from the wheels
ch-ch-ch-ch-ch-ch-ch-ch-ch-ch-ch-ch-ch-ch-ch-ch-ch-ch-ch-ch-
faster the car goes faster the ch-ch-ch-ch-ch-ch-ch-ch-ch-ch goes. metallic noise
Sound is coming from passenger side wheel. Assume front as you hear it when turning right or on straight but not at all when turning left.
Touch the brakes and the sound ch-ch-ch-ch-ch-ch-ch-ch stops immediately and then tarts as soon as you let off the brakes.
Can I assume this to be a sign telling me it is time to have my pads changed (I know from last service they are loaw) or is this something much more sinister??
Only just noticed today when roof was down - dont hear it with roof / windows up.
Old 03-04-2006, 04:22 AM
Bassoctopus's Avatar
Sounds like the pad wear marker to me
Old 03-04-2006, 04:27 AM
aldfort's Avatar
Sounds like contact between pad and disc due to:
1) something stuck on pad
2) edge of disc rubbing on pad if lip has formed
3) small stone behind disc trapped against backplate
4) pad rubbing on disc due to slight corrosion on caliper piston
5) slight wear in caliper assembly allowing pad to touch disc
6) slightly warped disc
at least these are my top 6 from recent years hope this helps.
7) something stuck in tyre tread
8) slight wear in front wheel bearing
Two more for luck
nickrg3's Avatar
does this mean I have to spend money on my car and my g/friend cannot moan about it because I have no choice but to spend the money??
ROCK ON!!!!
How many miles wouild you shuggest I have left to stock up on parts?
Old 03-04-2006, 04:31 AM
euan's Avatar
I read in a car mag recently about a similar noise they figured out was a stone stuck between pad and disc - they sorted it by some "prolonged" reversing to dislodge it - maybe worth finding a quiet road and trying a long reverse and some braking.
Old 03-04-2006, 04:32 AM
nickrg3's Avatar
Two more for luck
Whoa.. easy tiger thats way too many options for a saturday arvo!
I'm gonna go down my friendly zort / brake centre let them check em out I think.
Old 03-04-2006, 04:45 AM
nickrg3's Avatar
yeah - sounds like one of aldforts suggestions too. Will see if I can find somewhere tonight
Old 03-04-2006, 04:57 AM
Moggy's Avatar
absolutely
Old 03-04-2006, 05:12 AM
mikey k's Avatar
Yep pad wear indictor
Old 03-04-2006, 05:17 AM
nickrg3's Avatar
ok - good. Thanks
hmm.. now should I buy disks as well... 37k on them - they are looking a bit tired..
Quick Reply: new noise coming from the wheels
