new engine advice
Old 11-19-2009, 12:09 PM
scott-s2k's Avatar
Default new engine advice
Im in need of some info, i have a 1999 jap inport ap1 s2000 with 67000 miles on the clock and rescently has blown up so im opting for a new engine. iv sourced a 2006 fully rebuilt with new oem internals,oil pump,conrods ect it comes as a block with no extra's , i am aware that my99 had cable throttle and 9k rev limiter does the 2006 engine still have 9k rev limiter ! and it will have had the drive by wire (electronic throttle) but if i use my inlet manifold/throttle body ect will this work fine ! also will my ecu be ok 2 use ! and if i were to source a 2006 ecu would this be benifiscial ! and am i right in saying the 2006 engine has better lubrication and stronger oil pump!
thanks in advance for all ur help
Old 11-19-2009, 12:14 PM
Gaspode's Avatar
As I understand it...
There are no changes in the engine ( apart from something that uses less oil ).
Just swap over the interchangable bits.
Robert is your Mothers Brother.
Old 11-19-2009, 12:40 PM
loftust's Avatar
As it happens Gas...you're right
Make sure the 06 engine is a good one...can't think why such a new one has been re-built
Think about an MY04-05 engine...it 'might' prove less hassle.
Old 11-19-2009, 12:42 PM
scott-s2k's Avatar
i see,i would like to know exactly what differances there actually is between the old and new engines! cause if there where no changes i would prob build my99 engine with forge pistons,rods,valves ect ect
Old 11-19-2009, 01:48 PM
MB
Member
MB's Avatar
They all have forged pistons already AFAIK!
Old 11-19-2009, 01:50 PM
Gaspode's Avatar
It's only a gasket or something piss trivial that stops the oil seeping.
If you can get an 06 engine - get it.
If you can't - just top it up with oil as per the earlier engines.
Don't go DBW - it complicates things.
Old 11-19-2009, 02:02 PM
s2konroids's Avatar
IIWU mate, i'd get a non rebuilt 04 engine.
No pissing about with DBW and rebuilt engine need to be done properly, it seem from what I've read the F20C is a bit dodgy when it comes to rebuilds.
I think an o4 engine would probably run with your Jap spec car/ecu fine, i have had a spoon/J's ECU (jap ecu's realy) in a UK car, later ECU's run a bit leaner.
Old 11-19-2009, 05:59 PM
Ultra_Nexus's Avatar
There are different cam sensros on the new 06 engines, I rememebr seeing it so you' have to swap them over from your MY99.
The engine is forged as standard.
Like the other peeps have said, I would be looking for a low mile non rebuild.
Old 11-19-2009, 11:12 PM
Bibbs's Avatar
Over the years they changed the oil squirters (did you do yours?) and the oil pump was swapped (diff part number) in about 2004.
Just swap the new block in, and then put all the MY99 sensors on, using the MY99 ECU.
It's what I did and it was fine.
Old 11-20-2009, 12:38 AM
S2000_FUN's Avatar
It''s the same mods for 2.0 swap even if the tread is from 2.0 to 2.2liters
https://www.s2ki.com/forums/index.php?showt...&#entry11446556
Quick Reply: new engine advice
