New clutch?
New clutch?
Hi guys,
I've been to see a car this morning and it is everything that I want in an S2K but one thing bugs me.
It's on 88k and clutch pedal is rather high. Is it a complicated job to replace? I.e. it's not an engine out job or anything like that? I appreciate it depends where you are and suh but how much do you think for a new clutch assembly fitted?
Thanks.
Dan
Thanks.
Dan
UK Moderator
A couple of the Traders here will sell you a clutch for a great price, fitting is not too bad in general.
I think Tegiwa do a supply and fitting service, so check their threads in the Traders' section
You can adjust the engagement point with a 10mm wrench.
Look behind the pedal and there is a but you can loosen and turn the rod to make it engage higher or lower.
Tegiwa is right on my doorstep and although I chose to buy it from them I decided to fit it myself. If I ecmver had to do another one I'd get tegiwa to fit it for the price that they offer it at
Hi guys,
Thanks.
Dan
Thanks.
Dan
The plates on my old clutch were worn down to the rivets and all the springs were knackered (had an annoying buzz/vibration resonance around 3k rpm if I recall).
On a car with 88k if the clutch hasn't been done you need to factor this in or walk away. Budget on £800 I reckon by a good specialist to do the job.
Originally Posted by WRCGooseS2K' timestamp='1363436550' post='22407639
Hi guys,
Thanks.
Dan
Thanks.
Dan
I've just adjusted mine now. Allot better! I can actually cope with my CC clutch now
P:s it's a 12mm nut
Originally Posted by tailhappy' timestamp='1363466582' post='22408309
[quote name='WRCGooseS2K' timestamp='1363436550' post='22407639']
Hi guys,
Thanks.
Dan
Hi guys,
Thanks.
Dan
[/quote]
Did the clutch pedal feel light? Find out if its had one anyway as at 88k if hasn't, it will be worth doing (as the original will be well on its way).
The pedal on an S2k that's recently had a clutch will be feather light
