New battery needed?
New battery needed?
My battery keeps running flat if I don't use the car for a couple of days.
Is there something I should check before getting a new battery?
And where is the best/cheapest place to get a decent battery?
(I have a halfords discount card if that helps)
Cheers
P.s. Posting off my phone do can't search.
Cheers
Honda are surprisingly reasonable for OEM batteries although I believe there are 2 suitable part numbers and depending on the dealer they may try and sell you the more expensive type.
Dont know if you have tried keeping a trickle charger on to keep the battery topped between uses, it may just need a good charge if not being used often.
Could be the battery if you have no idea how old it is but it might be worth checking the alternator is working properly at the same time as you don't want to kill a new battery if the alternator isnt charging it properly.
UK Moderator
You can do a search on your phone - go to the bottom of the page and you'll see where it says "Search". alternatively, press where it says "Full Version" - this gets you to the normal page and you can search as usual.
Talk to Nick at Braille batteries Maybe a little overkill but will serve you very well!
http://www.braillebattery.co.uk
