Need tyres, HELP!
Need tyres, HELP!
can anyone help out, im looking for a set of Toyo R888;s in these sizes:
Front - 215/45/17
Rear - 245/40/17
tried camskill, rarerims, they dont have any. does anyone know where i could get them from?
thanks
Yumen
Front - 215/45/17
Rear - 245/40/17
thanks
Yumen
Originally Posted by Hypersonik,Jun 17 2009, 03:42 PM
Don't have any??? Why not, where have they gone?
does anyone know where would have these tyres in stock?
Are they out of stock on both sizes you posted? Or just the 245/40/17?
Mind you, the treadwidth (plus their structure and sidewalls) of the R888s is larger/wider than common radial tyres ( normal size of 245/40/17 rear) so in that case you would be fine by using a 235/40/17 tire.
On another note (although not sure how you use your car) you will need more than -2.0 camber in order to get them to work properly.
Kostas.
Kostas.
Kostas.
Kostas.
I have only -1deg on the front and they seem to grip very well TBH.
Ofcourse the grip, compared to normal tyres, will be far superior even if the geo is not setup for this kind of tire.
It is a general rule that tires such as semislicks ,or even worse slicks need a lot of camber in order to work optimal(to say it more properly).
Because the R888s are aimed at trackuse, one can assume that they will be under some great cornering forces throughout their life span.
Their very stiff sidewalls is one of their advantages and promise many many fast laps with very good feedback from the steering wheel of the car.
In order to be able to take the most out of your tire, when tracking, you need to make it capable of achieving the most traction when under load (when cornering hard). Thats where camber kicks in.
Although when on a straight line, a lot of your tire's surface may not contact with the tarmac at all, when cornering the exact opposite happens. The more you push the more traction you get. (Hope all this makes sense and sorry if my syntax has somewhere gone wrong).
Even TOYO, under the SET UP & CARE tab, suggest camber of 2.5-5.0 degrees although these numbers are restricted to S2000 owners except if they have installed an aftermarket coilover set.
Kostas
Kostas
Administrator
Try Event tyres
They offer discounts to S2KUK Members
See here:
http://www.s2kuk.com/s2kuk/Benefits/Suppliers.php
See here:
Originally Posted by kartaphilos,Jun 18 2009, 09:55 AM
I've got a new set at home if you're desparate. (but 225 fronts)
how much would you want for them, are they brand new?
i kinda am desperate, was wanting to buy my new rims but couldnt get tyres
also got spoon front & rear bump steer kit & coilovers comin soon so was wanting it all together so i can get it set up at same time.
