Need New Discs & Pads - Front & Rear
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
Hi Folks,
![hello.gif](https://www.s2ki.com/forums/images/smilies/hello.gif)
Well the car went into the boys and girls at Honda for an MOT and service.
It failed the MOT due to a misty headlight, moisture in the lens ( Been suggest to replace head light lens) I think it may need re-sealing
The service went ok, but have been advise the discs are well worn and the fronts are badly corroaded, and they will not make it to the next service interval.
![thumbsdown.gif](https://www.s2ki.com/forums/images/smilies/thumbsdown.gif)
After having been given a quote for genuie Honda disc's and new pads front and rear, I almost died of shock.
![eek3.gif](https://www.s2ki.com/forums/images/smilies/eek3.gif)
So question is would anyone recommend using aftermarket Disc's and Pad's and if so, What would you recommend????
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
Thanks
Kiwi
How much were you quoted for Discs and pads both front and rear??
You've put the fear into me!! As I suspect mine will also need doing in the next couple of months......
Originally Posted by Bassoctopus,Jun 1 2007, 11:06 AM
I think people use Brakes international and I've not heard anyone complain of a drop off in braking performance.
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
Originally Posted by ukphil78,Jun 1 2007, 11:19 AM
Might be a silly question, but is there an easy way to check how much wear is left on the pads and discs?
Any rules of thumb people use?
Kiwi
I'd get a second opinion on the discs and pads front if I were you. It's not an uncommon practice for a dealer to "recommend" new parts when the exsisting ones are perfectly fine.
Pads are easy to check visually, discs hmmm Ive always subscribed to the theory, if the face of the disc has a lip get them replaced. Surface corrosion is normal, where the pad doesnt contact the disc.
