my S is drinking coolant
my little lady, since a recent service has started drinking coolant at a rate of 1 coolant bottle every 3 weeks. ~(expensive habbit at honda coolant rates) Ive tried to spot any drips but i can not find any sign of a leak..
there is no oil residue and oil is ok. considered a head gasket or cylinder head issue.
I Have a Honda warranty but i Don't have the time to take it in.
anyone suggest something simple i may have overlooked.
I've has excessive coolant use on a few non-Hondas in the past (sometimes as much as half a bottle a day).
On the two occasions this happened when there were no visible leaks it was a head gasket job and a water pump problem.
I've also had a heater matrix problem (also in a non-Honda) and the reason I coudn't find the leak at first was that I was looking outside the car. The leak was inside the car and was only noticeable once the carpet was so saturated that the puddle started to form
(I suppose I should have noticed the peculiar smell earlier).
Just a few possibilities to consider - but if it was me I'd do my best to have the car checked by the garage asap. Best of luck in tracking it down.
![mad.gif](https://www.s2ki.com/forums/images/smilies/mad.gif)
No visible leak, no damp carpets?
Check your oil on dipstick, underside of filler cap and as far as you can see into the engine via the filler cap hole. Can you see any light Brown residue or slime? If yes it could be condensation but more likely as commented the head gasket.
You seriously need to get the system pressure tested ASAP, the S has an alloy block, you really dont want anything to warp due to a gasket issue.
IMO do not do many miles until you have had a pressure test, take it to a normal reputable garage, Honda will sting you for this service but some garages will do it for
1 Post
The only thing I can think of (that hasn't already been mentioned) is some kind of air pocket in the coolant system. But the amount your having to put back means it would be very large and you'd probably have noticed it already in the form of the car over heating.
I'd get it pressure tested ASAP.
Banned
![](https://www.s2ki.com/forums/images/s2ki/ranks/banned.png)
water's coming out or going in
it's pretty much that simple
coming out, the obvious signs are leaks - even very small leaks will result in a large volume loss over a week or so
culprits are obvious, like split hoses, weeping connections etc, and less obvious, like a duff radiator cap
going in is trickier - as said, water in the oil (check the dipstick and under the rad cap and in the rocker cover for 'mayonnnaise') or steam in the exhaust
rad cap would be my suggestion for something simple you 'may have missed'
hope it's that simple
good luck
good luck
