MOT failure
MOT failure
Hello all - just had the garage call and its failed its MOT on emissions, they're a good independent garage that I have used for years, they have tried everything to get it through... on fast idle the acceptable range (so I am told) is 0.970 - 1.030 and I came in a 1.198...
He checked on last year’s results and it sailed through on this - nowhere near as high..
The car is FHSH and well looked after with a lowish millage (35K)
Any advice other than go and see the stealers?
Thanks
TKL
Thanks
TKL
You are running very rich, or have a failed catalyser I expect.
First take a look for engine error codes (your CEL may be up the creek).
Perhaps a broken MAP or temperature sensor can cause overfuelling.
The O2 sensor may be shot.
CAT - I would buy a sport cat, the Honda is VERY expensive.
Excess fuel may have killed the cat too
m1 is right, get it looked at by a tuner as the cat shouldn't have died with that mileage, something may be up the creek
Originally Posted by loftust,Nov 6 2009, 01:45 PM
During my last MOT, I had to undergo the emissions test twice to pass. 'Apparently' the catalyst needs time to 'warm up' to work effectively.
As Steve says o2 sensor or CAT.
And as Neil says what your fuel consumption like this would point to the 2 above
How's your fuel comsumption been recently?
Give it a good drive with lots of vtec and retry it, if she drives like Miss Daisy that may help, O2 sensor also sounds worth a try, popular failure item.
