Mod recommendations?
Had a read through the history (again), I bought the S in June with 86k on the clock, last service was done by TGM with 82k on the clock. Receipt says "engine oils" - am I right in assuming that this is just the engine oil, and wouldn't included diff oil or gear oil?
Track day sounds good Driver tuition for track driving - any recommendations?
Ordered the glove box organiser .
Geo-setup would be worth doing after coilovers, otherwise I'll end up doing it twice seeing as I'll definitely be getting coilovers.
Question on coilovers - on the Civic I upgraded LCA's, rear camber adjuster, front camber arms to avoid excessive "stance", would I need to get additional parts on the S (apart from the coilovers)?
Might be worth checking now that you even can have the geo adjusted. If the bolts are seized it's something you can factor in getting sorted when you go for coilovers.
Tricky one on the geo. Leave it too long before getting coilies you may need new tyres too. And the issue of siezed bolts etc. If lowering too much you will need driveshaft spacers etc. Your £500 coilover kit could become a possible £1000 job.
UK Moderator
You don't need to fit anything else with new coilovers provided you don't lower it excessively.
Why do you want coilovers?
My previous owner had a full service at TGM and it clearly states Gearbox and Diff oils on separate lines of the receipt FWIW I spoke to them a couple of days ago to book in for a service and geo and they use Castrol Edge engine oil (not sure about the gearbox and diff though)
Track day/driver tuition - come to this: https://www.s2ki.com/s2000/topic/101...ay-9th-august/
I found with the Civic that the handling was better, maybe I'm just assuming the same for the S - like you suggested though, track day will be far more beneficial in terms of getting to know the car and what I'd like.
The gap between the arch and the tyres bugs me, but I'm not one for having a car sit excessively low either.
I'll get the geo done as I've had a thorough look through the documents from the previous owner and there's nothing there and I don't fancy spending a fortune curing something I can potentially prevent.
I did the usual coilies, exhaust system, intake, wheels, brake lines and all fluids but now wish I had done full powerflex bush replacement and derust/powdercoat before anything else. Its not fun or sexy but would ensure a good starting point for other mods.
Driver tuition is also good. Having spun mine shortly after purchase on a greasy road with cr@p tyres, doing a track day / tuition gave me lots of confidence back.
I went to get the alignment done today, was completely off both front and rear.
Unfortunately, we came to a snag, the rear toe nut (?) was stuck, so they couldn't sort out the adjustment - the guys were worried it would snap, so they said to get it fixed before completing the adjustment.
What would I need to do to get this fixed? Is it just a replacement nut?
