Misfitted mats
Misfitted mats
Anyone had probs with badly fitted mats?
New GT came with driver's mat fitted in wrong place - dealer fitted new mat of different style, but still irritating on 26k car
Also, radio reception on FM poor until dealer fixed loose connector - makes you wonder about quality of PDI !
I've got what I think is the same problem. The dealer fitted what look like stock S2000 mats. They fit ok but the hole in the mat is not in the same place as the anchoring pin in the floor of the car.
I think the pin can be moved "it is a bit loose" or I could punch another hole through the mat. I've not got round to looking at it yet.
I'm considering getting some Muz Mats anyway so I might just leave it.
P.S. Welcome to the forum
Fit of driver's side mat in my month old car is pretty poor behind the crossmember (just doesn't lie flat) , but I can't say its bothered me that much. More significant, albeit minor, irritations are missing bracket for driver's side Honda overmat (supplying dealer appears to have binned it rather than take trouble to fit it) and local dealer's inability to find part number to order a missing trim clip/button for centre console.
But despite pretty unimpressive performance of dealers, car is great, especially when ,and overall I've been pleased with build quality .
Hope your new mat has solved the problem.
Hi all
The bracket for the Honda mat can be moved, but you will need some plastic plugs, as the hole for the screw is there, but the hole is too big. (go to the dealer, and get some FREE)
As for the cut in the carpet on the cross member. That was done at the factory. You will find that the carpet is cut in several places (but still tacked in the corners), as the bracket can be fitted in two positions. I would strongly suggest you all go for MUZ MATS
Dave
Dave
Dealer promptly refitted 2 brackets which now fit perfectly with newly supplied blue edged mats that match exterior colour - but yet to test properly as car too young to V-Tec
Euan
Euan
Fit of driver's side mat in my month old car is pretty poor behind the crossmember (just doesn't lie flat) , but I can't say its bothered me that much....
