Misfire CEL appearing frequently
Old 05-28-2009, 08:41 AM
  #21
s2konroids's Avatar
Yup hence me asking is there any oil on the coilpack
The loose sparkplug could be the problem, so hopefully thats it. Its something I'm scared of a spark plug coming lose because some people on here have blown the engine/damaged it because of it coming loose, IIRC puppy was one poor bugger spark plug shattered and coilpack then bits scored inside
Clean up that coilpack, i used some carb cleaner but be careful with the seal right at the bottom.
If it is the sparkplug see what i mean about it not being 100% accurate in diagnosing exactly which cylinder it is.
Old 05-28-2009, 09:04 AM
  #22
GaryB's Avatar
Originally Posted by Ajs_s2k,May 27 2009, 03:57 AM
3. Sparkplugs - what condition are they in?
...loose.
DOH.
I know I should have checked sooner.
Feels crisper (but then I adjusted the throttle cable at the same time).
Anyway, lets see how she behaves tomorrow on the commute. Fingers crossed and thank you for all of your help everyone.
Old 05-28-2009, 09:05 AM
  #23
s2konroids's Avatar
Heyho, fingers crossed eh.
Old 05-28-2009, 09:52 AM
  #24
mikey k's Avatar
Lucky eascape!
Bibbs lunched an engine that way as well!
Old 05-28-2009, 10:09 AM
  #25
MB
Member
MB's Avatar
I posted a thread a while back about checking spark plugs - seemed to be a spate of it.
Old 05-28-2009, 10:53 AM
  #26
Bibbs's Avatar
Originally Posted by mikey k,May 28 2009, 05:52 PM
Lucky eascape!
Yup have a look at the spark plug seals too. They are on the cover and match up with the top of the plug wells.
Glad you caught it in time!
Old 05-28-2009, 11:18 PM
  #27
GaryB's Avatar
Well, early indications are good.
Smoother running and tickover and no sign of CEL this morning.
Will keep monitoring.
If it's happened to others and the consequences are so extreme, is it worth sticking a line in FAQ's for a check of torque settings on plugs?
Thanks again chaps, I can't tell you how much happier I am now.
s2kcolin
04-09-2011 09:05 PM
Slmd2K
10-30-2010 11:53 AM
Dembo
12-17-2006 01:04 AM
WarrenW
08-14-2006 04:04 PM
Quick Reply: Misfire CEL appearing frequently
