Mintex pads.
Old 12-30-2007, 10:31 AM
martin j's Avatar
Default Mintex pads.
Fitted new pads to the front last week, mintex extreme, although I used lots of copper slip they still squeal a lot, anyone else had a problem. maybe I should have put the grease between pads and shims as well as betwen the shims and caliper?
Old 12-30-2007, 10:36 AM
GrittyShaker's Avatar
I did that with my Mintex ones but they still squeal like barstewards.
Others don't seem to have a problem though. Vixen, for example, has Mintex pads but doesn't suffer from squealing. Well, she probably does if you jab her in the right spot.
Old 12-30-2007, 10:38 AM
RISLAR's Avatar
I Think you should have fella, the amount of times i've done that then had to do them again is nobodys business!! Mind they might be ok once they settle!!
Old 12-30-2007, 10:44 AM
I've done mine twice now, to no avail, so I decided to put up with it. They don't squeal under really hard braking though so I just leave off the brakes until as late as possible. Or, even better, just don't use them.
Old 12-30-2007, 10:45 AM
RISLAR's Avatar
Like your style
Old 12-30-2007, 10:48 AM
Vixen's Avatar
Actually I have developed a bit of an annoying squeak but they've been on the car for a while which is a bit strange.
Old 12-30-2007, 10:50 AM
It was you that developed AE's sister? How does that work then?
Old 12-31-2007, 04:18 AM
rallycol's Avatar
You can buy anti squeal material that sticks onto the back of the pads this usually cures it and they only costs a couple of quid
Old 12-31-2007, 04:22 AM
Ste_Nova's Avatar
you did peel off the sticker on the back when you fitted them?
Old 12-31-2007, 04:26 AM
Kiwi-S2000's Avatar
Mine make a noise too, once they are warmed up the squeal goes away.
Roll on summer
Quick Reply: Mintex pads.
