Minor Irritation Revs Dropping
Member
Worth a quick look in case it was full of condensation, but its pretty common for the idle to go bandy on the S2000 for various other reasons!
Under normal running the filter should be good for quite a while. The AEM is slightly more susceptable to picking up more crap due to its position though,
MB
MB
Originally Posted by Dark Blue Mark,Feb 5 2007, 05:13 PM
Simon - did they reset the ECU when they did the AC belt? Would have thought that was only a problem if the AC was running?
MB
MB
The air con clutch spins even when the aircon is off, so when it was jamming it was causing the engine to labour, revs drop or even stall.
You could see the belt stopping for a split second when blipping the throttle from under the bonnet.
We tried various things before just removing the aircon, one was to remove the auxillary belt completely and let the engine attempt to idle.
Member
Ah I get you Simon. Would have thought the alternator would pick up the load, but maybe if it didnt think it was on, it may cause a problem.
Good spot though.
MB
Good spot though.
MB
andrewh_11
05-09-2006 11:07 PM
