Mikes Supercharger Project Car - The History!
Old 03-29-2007, 01:47 AM
  #321
MB
Member
MB's Avatar
Ah, I thought you had some sort of data logging capability.
Its really a must if your are going to DIY it.
Of course, this is all much easier on a rolling road. I would try somewhere else than TDI. Where is your nearest Dyno Dynamics? Any good rolling orad will use their own wideband up the tail pipe to run the car, and they can then tweak the FPR for you. Its not rocket science, you just need to find a helpful place! They will also then verify your wideband to theirs just to give you some comfort.
You need to be able to log your AFR against rpm in a graph format as per the PLX logs that I had.
Watching the AFR gauge is ok once you are all setup, but you wont see the split second things its doing which is important for setting up.
And yep the fuel pressure is really only sueful on the move,and if you cant see it its not much good. Having said that, you will see the results on your AFR, you will just have to tweak the screw very carefully each run.
Obviously start off where its set (hopefully rich) and see what your 0-9000 rpm AFR log tells you.
Old 03-29-2007, 01:59 AM
  #322
mikey k's Avatar
I have some loggers are work that will take analogue in put, but it won't give me the RPM.
I'll have another chat with TDi I think I caught him on a bad day
Old 03-29-2007, 02:19 AM
  #323
MB
Member
MB's Avatar
I would go elswhere if it were me. A sympathetic dyno person can be the making or breaking of setting this up.
Link not working at the mo, but its a list of all (or most) of the RR's in the Uk.
http://www.racedandrallied.com/rolling-roads.php
Old 03-29-2007, 02:24 AM
  #324
mikey k's Avatar
I'll give it some more thought!
Let's get it running first
Old 03-29-2007, 12:39 PM
  #325
mikey k's Avatar
Anyone got and diagrams or tips on installing the ESM between the MAP and the ECU?
Getting nervous now!
Old 03-29-2007, 12:47 PM
  #326
MB
Member
MB's Avatar
Yep, do it at the ECU.
I can MSN tomorrow night and talk you through it if you like (which wire etc)?
Hope you got a soldering iron!
Old 03-29-2007, 12:52 PM
  #327
mikey k's Avatar
cheers Mark buggering with expensive electronics always worries me!
I'll take the laptop in the garage, better PM me your MSN "handle"
I'm a dab hand @ soldering!
Old 03-29-2007, 01:10 PM
  #328
UK Moderator
UK Moderator
BSM139's Avatar
I'm getting all exited now !
Is it the 15th April yet ??
Bharat
Old 03-29-2007, 11:29 PM
  #329
mikey k's Avatar
So am I and no, that's over two weeks away
Old 03-30-2007, 12:11 AM
  #330
MB
Member
MB's Avatar
PM you shortly then.
Im just going to retrieve the ECU diagrams for your MY.
Quick Reply: Mikes Supercharger Project Car - The History!
