Mikes Supercharger Project Car - The History!
Old 03-15-2007, 08:53 AM
  #171
Bibbs's Avatar
if you are running 11PSI you need a new map sensor (that will scale different - like the ones on the Zeitronix, they go from -1bar to +3.5bar, give or take).
Old 03-15-2007, 09:14 AM
  #172
markS2kcU's Avatar
Ok got it now, plus I didn't see that little -sign, looked all goobledeegoook to me.
I blame it on too much air to me brain, lovely day for topless driving and boost.
Old 03-15-2007, 09:22 AM
  #173
Bibbs's Avatar
Old 03-15-2007, 11:43 AM
  #174
mikey k's Avatar
Off to the garage for some more work! (get covered in under seal )
Dropped off the cat to have the wideband boss welded in FOC
Dropped off the bumper and spoiler for a hole filling session and respray
Old 03-15-2007, 12:30 PM
  #175
Bibbs's Avatar
When you next (or ever) down this way ? - Hope work was okay in the end.
You not going de-cat?
Old 03-15-2007, 12:34 PM
  #176
mikey k's Avatar
I'm not sure when I'm next down - too much $hit going on at the mo!
I've decide to run it as a "stock" comptech install for a few months.
Then I'll go, 750's, AEM EMS, decat, header. Did you change the fuel pump or FPR again whne you went to that spec?
Old 03-15-2007, 12:43 PM
  #177
Bibbs's Avatar
Fuel pump (SC one) is fine, swapped back to the stock FPR ..
Old 03-15-2007, 01:07 PM
  #178
AndyDoh's Avatar
Originally Posted by integraSi' date='Mar 14 2007, 09:58 PM
Well... I think the AEM's are not as fussy as the std ECU
I had AEM EMS on my car back when they first came out as well as an FJO wideband, plus I was "planning on going to 1.5Bar (approx 21psi when I'd built the engine) which is why I had the 3Bar sensor fitted
The tuners made a right hash of my mapping at first which really put me off the whole project, but Ben from Jakan helped me alot & sorted my MAP out for free a decent tuner make a whole world of difference
Old 03-16-2007, 03:23 PM
  #179
mikey k's Avatar
CAT is back with the extra boss welded in for wide band O2.
All the undersealing is done.
Front Nitrons are on.
No seized bushes, only one slightly corroded and easily sorted!
Got the whole weekend to crack on with it!
Old 03-16-2007, 03:26 PM
  #180
Bibbs's Avatar
Mase is only here till Monday
Quick Reply: Mikes Supercharger Project Car - The History!
